Zoho CRM JDBC Driver
The Zoho CRM JDBC Driver is a powerful tool that allows you to easily connect-to live Zoho CRM data through any JDBC capable application or tool! With the Driver users can access...
Public Key Infrastructure Core Package The comprehensive system required to provide public key encryption and digital signature services is known as a **Public Key Infrastructure...
DBeaver is free universal SQL client/database tool for developers and database administrators. It can work with any database server which has JDBC or ODBC driver. It supports...
SQL DAL Maker is a generator of DTO, Model, and DAO classes to access relational databases. Target programming languages: PHP, Java, C++, Python, and Go. To generate the class, you...
Action Chain is a powerful Eclipse plugin designed to streamline ABAP development by enabling users to manage chains of actions. With this plugin, developers can automate...
Explain PostgreSQL Analyzes EXPLAIN plan from PostgreSQL and related (Greenplum, Citus, TimescaleDB and Amazon RedShift). Shows plan and node details and visualizations with...
Cppcheck is a static analysis tool for C/C++ code. It provides unique code analysis to detect bugs and focuses on detecting undefined behaviour and dangerous coding constructs. The...
Design and Verification Tools (DVT) is an integrated development environment (IDE) for the design and verification engineers working with SystemVerilog, Verilog, VHDL, e, UPF, CPF...
Sigasi offers the leading plugin for VHDL, Verilog, SystemVerilog, and mixed language projects. Makes standard editors obsolete Type-time code analysis Error reporting while you...
This Eclipse plug-in adds syntax highlighting support for the following languages/file formats utilizing Eclipse TM4E: Apache HTTP configuration files - https://httpd.apache.org...
